This command enables the dynamic hostname feature, which displays either the area name or the SNMP name instead of a IS-IS router system ID in select show commands.
| area_name | Specifies the name of the IS-IS process for which the dynamic-hostname feature is to be enabled. |
| area-name | Specifies that affected show commands display the area name instead of the IS-IS system ID. |
| snmp-name | Specifies that affected show commands display the SNMP name instead of the IS-IS system ID. |
Disabled.
This command enables support for the dynamic hostname exchange feature defined by RFC 2763.
The following command enables the display of IS-IS area names:
enable isis area areax dynamic-hostname area-name
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
